LRiess
[X50 Ultra Complete] Battery charge limit
2919 5
Hey Dreame team,
as I am working in the battery management sector and have quite some experience with battery aging I have a functional wish.
The problem: The robots have no configurable charge limit, and always charge up to 100% and stay at this charge level till next usage. This is a condition which increases battery aging tremendously.
Functional suggestion:
- Configurable battery max charge threshold. Which would be the maximum charge level the battery can charge up to.
- Configurable battery storage charge threshold. Which would be the charge threshold the robot is charged up to after completing a activity.
- Button to activate charging to let the robot charge up its max charge threshold.
- Smart charging logic: If a task is scheduled that the robot starts charging some hours before the task to charge from the storage charge threshold to the max charge threshold.
I would really appreciate such a functionality and hope to get some feedback.
All the best!
Thank you for your contribution to a very important topic. However, on my Matrix10, I can already set a charging limit of 80% or 90%.
OG825963 2 Beitrag
Ist beim Dreame Aqua10 Ultra Roller Complete auch zum einstellen 80, 90, 100% Laden
2-4-2026 17:49:51 CH Übersetzen
Guten Morgen, ja, der Dreame Aqua10 Ultra Roller Complete unterstützt die Einstellung eines Ladelimits. In der App können Sie zwischen 80 %, 90 % oder 100 % Ladebegrenzung wählen, um den Nutzungsbedarf optimal mit der Batterielebensdauer in Einklang zu bringen.
3-4-2026 08:22 DE Übersetzen
Hello, thank you very much for sharing such professional and constructive feature suggestions.
Currently, some models already support setting a battery charging limit, which helps optimize battery health management to a certain extent. Your suggestions regarding configurable charging thresholds, storage charge levels, and intelligent charging logic are highly valuable. We have carefully noted them and will forward your feedback to our product and R&D teams as an important reference for future feature optimization and improvements.
Thank you for your continued interest and support. We also warmly welcome you to keep sharing your valuable experience and insights with us.
LRiess 4 Beitrag Themenstarter
Thanks for all your replies, I really hope that the feature also makes it to the X50 as a software update.
UID:DZ289594 DE
