VR298253
[A2] No 3D mapping
Since I started the robot this spring, it has no 3D mapping.
Even when the WiFi signal is strong, the message is that the map could not be downloaded because of a weak signal…
Can somebody help?
Regarding the issue of being unable to download the 3D map, please try restarting the device and then attempt to download it again.
It may also be caused by a weak network signal leading to the download failure. We recommend downloading “Speedtest China by Ookla” from the Apple Store to check your network signal strength.
UID:VR298253 CH
  • 5Beiträge
