BT731227
Smart home
How too clean home deeper?
Dieses Thema wurde zuletzt von BT731227 am 2-7-2026 11:05 bearbeitet
BBB 1 Beitrag
Oh Lord. Your robot needs a little bit more love. 😉 I don’t know the Model but I’m pretty sure there are newer models with better cleaning performance. But maybe it’s necessary to clean the floor once by hand and maintain the cleanliness by the robot.
Wadl_Stutzn 2 Beitrag
Yeah your robot dont looks very well 😅😅 Its also seems that your floor has a lot of scratches, in which dirt can stay easily.
Do you regularly switch the mops and filters?
We recommend trying the following methods to improve cleaning performance:
1. Repeat cleaning on specific areas
For areas with heavier dirt, you can set up targeted zone cleaning or increase the cleaning frequency to achieve better results.
2. Perform regular maintenance
We suggest cleaning the following components regularly:
Filter (to maintain strong suction)
Main brush / side brush (to remove tangled hair and debris)
Mop pads (to prevent spreading dirt)
3. Pre-treat stubborn stains
For stains that have not been cleaned for a long time, we recommend lightly pre-cleaning them manually before running the robot. This can significantly improve the final result.
If the performance is still not satisfactory after these adjustments, please feel free to share your device model and current settings. We will be happy to help you further optimize your cleaning results.
5-6-2026 07:47:56 DE Übersetzen
I’m having dreame rll82
1-7-2026 22:22 CH Übersetzen
UID:BT731227 CH
  • 5Beiträge
