dreame4test
[R20] My R20
I purchased the Dreame R20 as a complement to my Dreame X40 Master, and so far it has been the perfect combination.
While the X40 takes care of the daily floor cleaning automatically, there are always areas a robot vacuum can’t reach easily: stairs, furniture, corners, the car, or quick cleanups after cooking.
This is exactly where the R20 shines.
✔ Strong suction power
✔ Lightweight and easy to handle
✔ Perfect for stairs and furniture
✔ Ideal for quick cleanups
✔ Great addition to a robot vacuum
The biggest advantage is convenience. Instead of moving furniture or waiting for a full cleaning cycle, I can grab the R20 and clean the area in seconds.
For me, a robot vacuum doesn’t completely replace a cordless vacuum—and the R20 proves why. Together with the X40 Master, it creates a cleaning setup that covers virtually every situation.
If you already own a robot vacuum and are looking for a practical cordless vacuum as a supplement, the Dreame R20 is definitely worth considering.
⭐⭐⭐⭐⭐ 5/5
Keine Kommentare
UID:LU228251 CH
  • 6Beiträge
  • 3Freunde
