GC084488
[L40s Pro Ultra] Extendeable side brush
The robit is not using the exentable side brush under overhanging kitchen Furniture.
since you OS is completly locked. How to motivate the robot to use side brush in the kitchen?
Have a look in the settings under ‘Ki-controlled MopExtend settings’. Everything there should be enabled, except perhaps the intensive cleaning of furniture legs, and the ‘Frequent’ setting should be set to a high frequency.
Hello, thank you for your feedback.
Regarding the issue you mentioned with the side brush not extending properly in the kitchen area, we recommend adjusting the settings in the Dreamehome App. You can set the “side brush / mop extension frequency” to high, and disable “Collision Avoidance Mode” under “Floor Cleaning Settings.” This may help improve the robot’s edge-cleaning performance.
UID:GC084488 DE
