Ness
Language
639 2
Hello
How do I change the language of the forum?
I am in Switzerland and I have access to the German speaking forum but I only speak French or English
Can I change it somewhere?
Many thanks
As far as I know, there's no way to change the forum's language per se; the only workaround is to use the "Translate" button below the posts.
Thank you for your feedback.
At the moment, the forum language cannot be changed separately. The forum you access is determined by the country/region selected in your app.
If you prefer to use French, we recommend changing the country/region setting in the app to France. After doing so, you should be able to access the French-language community forum.
We have also noted your suggestion regarding forum language options and will forward your feedback to the relevant team for consideration in future improvements.
UID:LZ829360 CH
